A professional 3D scanner that improves your business process. The Scoobe3D is a world-exclusive handheld 3D scanner. This easy-to-use scanner can scan any material precisely, even reflective surfaces. The Scoobe3D GmbH is constantly working on a product that truly adds value. Their result: The Scoobe3D – A professional 3D scanner based on a new revolutionary scanning technology. With this portable 3D scanner, you can create seamless 3D models of any visible material and precisely scan reflective surfaces without having to post or pre-process them. At the bottom line, the Scoobe makes 3D as easy as 2D. Let us shape the future in 3D together!
Related topics
Topic | Replies | Views | Activity | |
ScanX uses Cesium ion SDK to visualize and analyze point clouds | 0 | 360 | January 24, 2023 | |
Loading oblique photography and adding a water surface to oblique photography. The water surface wants to refract the reflection of oblique photography. How to achieve this | 0 | 63 | May 13, 2024 | |
Recherche outil 3D | 0 | 218 | March 10, 2021 | |
New boat 3D models for boats in sail-pro plugin to Virtual Regatta | 0 | 271 | April 2, 2023 | |
Millimeter precision point clouds running in Cesium | 1 | 338 | June 25, 2021 |
