Putting a billboard on the outline of an ellipse graphic
I was wondering what the best way to put a billboard on the outline of an ellipse graphic would be.
My issue is trying to determine the position to place it in. Right now I have:
position: new Cesium.Cartesian3(entity.position._value.x + entity.ellipse.semiMinorAxis, entity.position._value.y, entity.position._value.z)
but that doesn't work. I'm not quite sure how to approach this.
I want to use the billboard to adjust the radius of the ellipse.
Cesium 1.47, Centos, Firefox
Your code would work if you were using a flat model of the earth. You’ll need to take into account the curvature, depending on how big your ellipse is.
I think this would be easier to do in Cartographic coordinates. The answer here describes a quick way to convert the offset in meters (the radius) to long/lat: https://gis.stackexchange.com/a/2980
So it could look something like this:
// Get circle position in lat/long
var position = Cesium.Cartographic.fromCartesian(circle.position.getValue(time));
var radius = circle.ellipse.semiMajorAxis.getValue(time);
// Set the billboard height above the circle
position.height = circle.ellipse.height + 30000;
// Convert radius offset to longitude as described in https://gis.stackexchange.com/a/2980
position.longitude += (radius / (111111 * Math.cos(position.latitude) * (180/Math.PI)));
// Convert back to Cartesian3
return Cesium.Cartographic.toCartesian(position);
Here’s a working example to illustrate this. Let me know if this helped!
Thank you so much! This helped a lot. It's a tiny bit off, but I think I can fix that.
