Q. Mipmaps embed in Compressed Texture
Hi I’m testing about CRN(DXT) texture for B3dm.
**I think **
current cesium (1.5x) has no ability to load mipmaps in compressed texture(ex. dxt with mipmaps) yet.
var mipmap =
(!(defined(internalFormat) && PixelFormat.isCompressedFormat(internalFormat))) &&
((sampler.minificationFilter === TextureMinificationFilter.NEAREST_MIPMAP_NEAREST) ||
(sampler.minificationFilter === TextureMinificationFilter.NEAREST_MIPMAP_LINEAR) ||
(sampler.minificationFilter === TextureMinificationFilter.LINEAR_MIPMAP_NEAREST) ||
(sampler.minificationFilter === TextureMinificationFilter.LINEAR_MIPMAP_LINEAR));
// GLTF_SPEC: Support TEXTURE_CUBE_MAP. https://github.com/KhronosGroup/glTF/issues/40
if (mipmap) {
tx.generateMipmap();
Have any plan to implement it?
thanks cesium team.
Shyoo.
We actually just recently implemented this (loading KTX) in order to support HDR images for image-based lighting (IBL). This is the class:
It should be able to load the mipmaps. Although I’m not sure if it’ll correctly use it when loading in b3dms. Do you have a sample file that you’ve tried?
