Hi there @kevin_ring,
For loading in unreal engine which will be considered first? Availability information present in per .terrain file or from the layer.json.
I have dem data as shown in the image. If I put two element in array at zoom lvl 15 will it considered as valid metadata file or fail in parsing??? Main reason for doing is that I don’t want to make network request for tiles where I don’t have data.
This kind of JSON structure will consider like every zoom level has array of multiple rectangle in loading Unreal engine ?
Example Shema
"tilejson": "2.1.0",
"name": "Srinagar_DEM_30m",
"description": "",
"version": "1.1.0",
"format": "quantized-mesh-1.0",
"attribution": "",
"schema": "tms",
"extensions": [ "octvertexnormals" ],
"tiles": [ "{z}/{x}/{y}.terrain?v={version}" ],
"projection": "EPSG:4326",
"bounds": [ 0.00, -90.00, 180.00, 90.00 ],
"available": [
{"0":[{"x_start":0,"x_end":1,"y_start":0,"y_end":0}],
"1":[{"x_start":0,"x_end":3,"y_start":0,"y_end":1}],
"2":[{"x_start":0,"x_end":7,"y_start":0,"y_end":3}],
"3":[{"x_start":0,"x_end":15,"y_start":0,"y_end":7}],
"4":[{"x_start":0,"x_end":31,"y_start":0,"y_end":15}],
"5":[{"x_start":42,"x_end":53,"y_start":15,"y_end":26}],
"6":[{"x_start":85,"x_end":106,"y_start":31,"y_end":53}],
"7":[{"x_start":170,"x_end":213,"y_start":63,"y_end":106}],
"8":[{"x_start":341,"x_end":426,"y_start":127,"y_end":213}],
"9":[{"x_start":682,"x_end":853,"y_start":255,"y_end":426}],
"10":[{"x_start":1365,"x_end":1706,"y_start":511,"y_end":853}],
"11":[{"x_start":2730,"x_end":3413,"y_start":1023,"y_end":1706}],
"12":[{"x_start":5461,"x_end":6826,"y_start":2047,"y_end":3413}],
"13":[{"x_start":5469,"x_end":5469,"y_start":2047,"y_end":3413},
{"x_start":5472,"x_end":5472,"y_start":2047,"y_end":2051}]
