I'm trying write a tool to batch mesh with same matereial in gltf file and convert it into b3dm file. But I don't understand the neccessary of putting batchId into vertex attributes. Since it will consume more memory than just put item id and it's start/end index in the batch table. Does anyone has the same question? Correct me if I'm wrong.
None.
I am trying to write a pipeline tool to convert gltf to tileset. And I think the first step is to batch meshes in gltf and assign the batchId to each batched mesh. However, I'm a little confused about the neccessary of batchId attributes.
The lastest version.
Any response from you guys is appreciated.
Thank you in advance.
That actually sounds like it would work. I asked around the team and it sounds like this design was just consistent with how things are stored in the batch/feature tables.
If it sounds like it might save a lot of memory, I’d encourage you to try it and open up an issue on the 3d tiles repo (https://github.com/AnalyticalGraphicsInc/3d-tiles/issues) making a case for it. It’s probably not going to change the spec but it might inform future decisions.
I also meant to ask, is this tool you're working on open source?
If it sounds like it might save a lot of memory, I'd encourage you to try it and open up an issue on the 3d tiles repo (Issues · CesiumGS/3d-tiles · GitHub) making a case for it. It's probably not going to change the spec but it might inform future decisions.
On Saturday, January 19, 2019 at 4:17:59 AM UTC-5, fanqil...@gmail.com wrote:1. A concise explanation of the problem you're experiencing.
None.
Thanks for you reply. I opened up a issue here. Run-length encoded feature IDs · Issue #366 · CesiumGS/3d-tiles · GitHub.
The tool I'm building now is in my private repo now since the major party is not finished yet. But I will change it to a public repo as soon as I think it's ready. Thanks again.
