According to https://github.com/AnalyticalGraphicsInc/3d-tiles/blob/master/specification/TileFormats/Batched3DModel/README.md,
Semantic
Data Type
Description
Required
BATCH_LENGTH
uint32
The number of distinguishable models, also called features, in the batch. If the Binary glTF does not have a batchId attribute, this field must be 0.
Yes.
So, the max number of features in the batch can be 2^32. Is this correct?
And,
The batchId parameter is specified in a glTF mesh primitive by providing the _BATCHID attribute semantic, along with the index of the batchId accessor. For example,
"primitives": [
"attributes": {
"_BATCHID": 0
"accessors": [
"bufferView": 1,
"byteOffset": 0,
"componentType": 5125,
"count": 4860,
"max": [2],
"min": [0],
"type": "SCALAR"
The accessor.type must be a value of "SCALAR". All other properties must conform to the glTF schema, but have no additional requirements.
From above description, the batch_id can be an UNSIGNED_INT(5125), so each batchId can be any integer range [0, 2^32]?
But I see below definition in shader.
attribute float a_batchId;
From IEEE754, 4 byte float can only represent only 2^23 Integers.
So, any limitations or restrictions on batchId?
