I’m trying to add label for polyline by editing the entities created with geojsonDataSource.
For polyline, I’m calculating the center of it and set entity.position, then create a label for entity.label. Yet there are too many labels created.
let promise = Cesium.GeoJsonDataSource.load(config.url, {clampToGround: true});
promise.then(dataSource => {
dataSource.id = id;
dataSource.name = config.name;
dataSource.show = false;
let entities = dataSource.entities.values;
entities.forEach((entity, idx) => {
let properties = entity.properties.getValue(Cesium.JulianDate.now());
if (entity.billboard) {
entity.billboard = undefined;
createLabel(properties[layerObj.labelKey], 0, entity)
if (entity.polyline) {
entity.polyline.distanceDisplayCondition = new Cesium.DistanceDisplayCondition(0, 1e5)
let polyPositions = entity.polyline.positions.getValue();
let polyCenter = Cesium.BoundingSphere.fromPoints(polyPositions).center;
polyCenter = Cesium.Ellipsoid.WGS84.scaleToGeodeticSurface(polyCenter);
entity.position = polyCenter
createLabel(properties[layerObj.labelKey], 2, entity)
entity.polyline.clampToGround = true;
entity.polyline.zIndex = 10;
entity.polyline.width = 2;
// entity.polyline = undefined;
if (entity.polygon) {
entity.polygon.distanceDisplayCondition = new Cesium.DistanceDisplayCondition(0, 1e6)
let polyPositions = entity.polygon.hierarchy.getValue(Cesium.JulianDate.now()).positions;
entity.position = polyCenter;
createLabel(properties[layerObj.labelKey], 1, entity)
let color = Cesium.Color.fromRandom({
alpha : 0.1
entity.height = 0;
entity.outline = true;
entity.polygon.material = color;
// entity.polygon.heightReference = Cesium.HeightReference.RELATIVE_TO_GROUND;
// entity.polygon.outlineWidth = 10.0
// entity.polygon = undefined
dataSource.show = config.show;
if (config.flyTo) flyTo(dataSource, viewer)
}).otherwise(err => {
console.log(err);
The use case is to load geojson poi info(each geometry with an label) with geojsonDataSource. The polygon with label works, yet for polyline, since I’m using them for roads, ideally, I would like to dynamically render 1 or 2 label(road name) along the polyline in the viewer.
Cesium 1.61, mac Mojave 10.14.6, Chrome 77.0.3865.90 64bit
Thank you so much
