Questions about using Line Trace By Channel
hello.
I have a question related to Line Trace By Channel.
I’m trying to place a tree actor using Line Trace By Channel.
Latitude, longitude and height values are required for placement.
Latitude and longitude values are used by creating a csv file for testing.
However, for the height value, I tried to use the location where I hit the tile through Line Trace By Channel.
But the result looks like the picture below.
Tiles don’t collide properly, is there a way to fix it?
Blueprint is also attached.
Turn on the translator and ask a question.
thank you
The height may change based on what level of detail tiles are loaded at the time. (For example, a lower level of detail tile may have shallower peaks and valleys than a higher one).
When you’re doing the Line Trace, are you doing it right as the program starts?
Thank you for answer.
I was able to figure out the problem by getting a hint from the answer.
