Hi!
Is there a way to raise polygon intance to top?
What i mean is a function like primitives.raiseToTop () that gets a geometry instance/instance id and raises it to top.
Also, can i get the geometry instance by its id?
If you break the geometries into separate primitives, you can use primitives.raiseToTop(), but it is not possible to reorder geometries inside a primitive.
If you need to get a geometry instance from an id, keep a separate object that maps the id to the geometry instance (or maybe even make the id the geometry instance). For efficiency Cesium does not store the instance. From the tutorial:
“Using id, instead of the reference to the instance itself, allows the primitive - and our application - to avoid keeping a reference to the full instance, including its reference to the geometry, in memory after the primitive is constructed. Since a geometry can contain several large typed arrays, this allows us to save a significant amount of memory.”
Patrick
Can you give an example for your proposed solution?
Let’s say I do this pseudo code which creates 2 serieses of polygons and adds them to a primitive:
CreatePolygons() and put them in array polygons;
primitves.add(polygons);
Now that the polygons are inside the primitive collection, how do I go about ordering them? Using “raise” and “lower” or “raisetotop” or “lowertobottom” seem to have no effect I can see.
Thanks
Here’s a sample code to make it clearer:
var myCesium = new Cesium.Viewer(elm.attr('id'),{
imageryProvider : new Cesium.ArcGisMapServerImageryProvider({
url : 'http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer'
baseLayerPicker : false
var pins = {};
pins.pinBuilder = new Cesium.PinBuilder();
pins.billboardCollection = new Cesium.BillboardCollection();
myCesium.scene.primitives.add(scope.cesium.billboardCollection);
function createPolygon(x, y, color){
// Create the polygon geometry.
var index = 0;
var primitiveIndex = scope.cesium.viewer.scene.primitives._primitives.length;
var positions = Cesium.Cartesian3.fromDegreesArray([
x[1], y[1], x[1], y[0],x[0], y[0],x[0], y[1]
//Create a blank, solid colored pin.
billboardCollection.add({
image : scope.cesium.pinBuilder.fromColor(Cesium.Color.ROYALBLUE, 24),
verticalOrigin : Cesium.VerticalOrigin.BOTTOM,
position : Cesium.Cartesian3.fromDegrees((x[1]+x[0])/2, (y[1]+y[0])/2, 0)
if (angular.isUndefined(color))
color = Cesium.Color.fromRandom({alpha : 1.0});
// Create a geometry instance using the polygon geometry.
var polygonInstance = new Cesium.GeometryInstance({
geometry : Cesium.PolygonGeometry.fromPositions({
positions : positions,
vertexFormat : Cesium.PerInstanceColorAppearance.VERTEX_FORMAT
attributes : {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(color)
return polygonInstance;
function insertPolygons(polygons){
// inserts a polygon to the map
if (polygons.length){
myCesium.scene.primitives.add(new Cesium.Primitive({
geometryInstances: polygons,
appearance: new Cesium.PerInstanceColorAppearance({
closed : true,
translucent : false
function simulatePolygons(data){
// this function constantly adds polygons (or updates existing)
// some/time => update/ms
var some = 10; //updates
var time = 1000; //ms
var index = 0;
function addSome(){
var draw;
var newPolygons = [];
var color = Cesium.Color.fromRandom({alpha : 1.0});
for (var i=0; i<some; i++){
newPolygons.push(createPolygon(data[index++].x,data[index].y,color));
insertPolygons(newPolygons);
setInterval(addSome, time, 10);
simulatePolygons(getDataFromServer());
So now (if I didn’t ruin it during the simplification) I have a primitive collection of primitive collections that inside I have polygons. Can you please direct me as to how to use the raise/lower commands in order to control which primitive collection will be on top?
