Getting the surface of terrain and create it as polygon
Im trying to create a polygon on a terrain surface copying its texture/surface and elevate it on top. Is there any way to do it or some hint how it can be achieved?
Thanks!
Basically, I want the lower polygon to be similar to the one on the top. Right now the top part doesnt have a surface.
Hi, It would be more easy to understand if you provide any sample code or sandcastle example.
Hello, what I want is similar to this sandcastle
I want the polygon to clamp on the terrain getting its surface, and I want to float that polygon upward. Is that possible?
The main goal is to capture the shape of the terrain then float it upward.
I tried using GroundPrimitives but I am not able to move the polygon upward and maintain its shape.
Thank you!
Hi @iramgelb,
there is no simple solution for that. The polygon in your example only has coordinate-information of its outline (normal behaviour of a polygon) and “colorizes” the terrain underneath it. It has no information about the shape of terrain inside it. For that you would need a mesh or something similar, but to my knowledge that is not part of the Cesium API.
The best way in my opinion would be, to simulate a polygon with multiple points with a height of “terrain + someValue”. You can get the terrain height with e.g. sampleTerrainMostDetailed.
But maybe some folks, who are more advanced, can help you.
Best, Lennart
Thank you for your prompt reply regarding this matter. I will try out your suggestion and see how it goes. :slight_smile:
