I’m trying to get a polygonGraphic(2D plane mapped to the terrain) to clamp to the terrain. I’m not setting height or extrudedHeight, but I am using an ImageMaterialProperty with a CallbackProperty for the repeat property. Image attached. Is this just a limitation of PolygonGraphic? The original set of points I was using for the hierarchy property didn’t have elevation values, but I did try to get the elevation values from the Cesium.sampleTerrainMostDetailed function.
The code is quite involved, but I can probably create a sandtable example if this does sound like a bug.
This feature is a standard military(2525) way of representing a minefield on a map. See the attached photo. Basically the polygon’s material should scale based upon the screen space. The larger the area on the view the higher the repeat value should be set for the ImageMaterialProperty.
v1.36, windows 7, chrome
Scott
