Polygon not clamped to ground when changing material properties
While fiddling with a couple of GeoJSON files draped on the STK Terrain, I noticed that if I changed the material properties from a solid color to a striped one, the entity wouldn´t be “clamped to the ground” anymore, and thus, it would slide and mode whenever I moved the camera.
Testing this in the Sandcastle App (Ground Clamping), I noticed the same, but this time the polygons would disappear.
Did I miss something obvious in my code or is this feature working as expected/still not introduced?
Thanks a lot!
To the Cesium Sancastle App for Ground Clamping ( here ), add:
var PolyMaterial = new Cesium.StripeMaterialProperty({
evenColor: Cesium.Color.LIGHTBLUE.withAlpha(0.5),
oddColor: Cesium.Color.BLUE,
repeat: 50
Then, change the material property from the Polygon on line 86 from “Cesium.Color.BLUE.withAlpha(0.5)” to “PolyMaterial”
Mainly to visualize Areas of Interest differently
Cesium 1.38, Win7 64 bit, Firefox 52.1
Thanks again for your time!
Hi there,
Unfortunately GroundPrimitives do not yet support other materials. I’ve bumped this GitHub issue where we are tracking the feature. If you happen to have the bandwidth, contributions are welcome!
Thanks!
Gabby
We’ve just added support for materials on ground polygons, and the feature will be included in the upcoming Cesium 1.46 release available on June 1st.
Thanks!
-Hannah
