I just upgraded my Cesium version from 1.15 to 1.24, and I wanted to take advantage of the terrain clamping of ground primitives. I have some very long polygons that I’m creating using PolygonGeometry as follows:
var groundPrimitive = scene.primitives.add(new Cesium.GroundPrimitive({
geometryInstances : new Cesium.GeometryInstance({
geometry : new Cesium.PolygonGeometry({
polygonHierarchy: {
positions: positions
attributes: {
color: Cesium.ColorGeometryInstanceAttribute.fromColor(color)
appearance: new Cesium.PerInstanceColorAppearance({
closed: true,
translucent: true
As I zoom further out the the polygons appear to disappear below the terrain as you can see in the following screen captures:
Is this due to low resolution elevation data? Is there something I can do to keep the polygons from disappearing?
The same thing appears to happen if I create a polygon entity. I took the section of code to create a polygon from the Sandcastle Ground Clamping example and replaced the positions with a new set of positions. You don’t have to zoom out very far for the polygon to disappear.
The following should drop right into Sandcastle:
var cesiumTerrainProviderMeshes = new Cesium.CesiumTerrainProvider({
url : ‘https://assets.agi.com/stk-terrain/world’,
requestWaterMask : true,
requestVertexNormals : true
viewer.terrainProvider = cesiumTerrainProviderMeshes;
function drawPolygon() {
var e = viewer.entities.add({
polygon : {
hierarchy : {
positions: [new Cesium.Cartesian3.fromDegrees(-80.52240492379808,26.07276605035512),
new Cesium.Cartesian3.fromDegrees(-80.38142436812922,26.072221561466225),
new Cesium.Cartesian3.fromDegrees(-80.3813686168645,26.08386721144594),
new Cesium.Cartesian3.fromDegrees(-80.52234917227406,26.084411700334833)]
material : Cesium.Color.BLUE.withAlpha(0.5)
viewer.zoomTo(e);}
drawPolygon();
The only difference I see between this and the Sandcastle example is that I’m using “new Cesium.Cartesian3.fromDegrees”.
Thanks for including the Sandcastle example! That made this problem really easy to reproduce.
This looks like a bug in Cesium to me. I’ve filed an issue on our GitHub so we can look into it: https://github.com/AnalyticalGraphicsInc/cesium/issues/4231
