We are drawing polygons, and, among 1500+ polygons we draw there are particular two which make Cesium crash. Any one of these two works fine, but two drawn together appears to be deadly for Cesium. Need help figuring out what makes these two polygons so special to cause such an effect so we could get it under control.
Following code illustrates the matter. It can be copied to Sandcastle and run to see the crash.
Suggestions?
var polys =
“172.634577109946,-43.5297673648253,0 172.634804217336,-43.529495739866,0 172.634806485168,-43.5294930288697,0 172.634861434736,-43.5294273070786,0 172.63494253963,-43.5293130740366,0 172.635009486553,-43.5292016873973,0 172.635114926283,-43.5290395485974,0 172.635114417915,-43.5288578214237,0 172.635301832678,-43.5288575599225,0 172.635408591283,-43.5288574118932,0 172.635599024564,-43.5288571506268,0 172.635607810592,-43.5288571384131,0 172.63566038171,-43.5288570665048,0 172.635662432337,-43.5288570636994,0 172.635662432432,-43.5288570624672,0 172.636245599313,-43.5288562513054,0 172.636260035845,-43.5288562340014,0 172.636496957722,-43.528855901815,0 172.636497169339,-43.5289387006143,0 172.636497389941,-43.5290241274363,0 172.636497536498,-43.5290825429202,0 172.636498133855,-43.5293102642739,0 172.636498648162,-43.5295082916736,0 172.636498648325,-43.5295103618935,0 172.636498648185,-43.5295124230153,0 172.636498799238,-43.5295701455729,0 172.636498801941,-43.5295717297606,0 172.636499266063,-43.5297491722762,0 172.636478143775,-43.5297645959975,0 172.636157010028,-43.5297650671343,0 172.635513406837,-43.5297660022342,0 172.634730804991,-43.5297671412286,0 172.634577109946,-43.5297673648253,0”,
“172.632717748155,-43.5252174117892,0 172.632718750085,-43.5252174149852,0 172.632718749997,-43.5252174111734,0 172.632717748064,-43.5252174079776,0 172.632717748155,-43.5252174117892,0”
for (var i in polys)
var poly = polys[i];
var degarray = ;
var pts = poly.split(’ ');
for (var i in pts)
var pt = pts[i].trim();
var coords = pt.split(’,’);
if (coords.length>1)
var lng = parseFloat(coords[0]);
var lat = parseFloat(coords[1]);
degarray.push(lng);
degarray.push(lat);
viewer.entities.add
polygon :
hierarchy : Cesium.Cartesian3.fromDegreesArray(degarray),
heightReference : Cesium.HeightReference.CLAMP_TO_GROUND,
clampToGround : true
The answer to this should be obvious.
Cesium 1.50. Chrome. Tried on both Windows and Lynux - both crash.
