Patrick,
I am not seeing the issue with the ground primitive. The ground primitive is not going to meet my needs, was this information needed to isolate where the problem may exist?
Sample code to test the ground primitive:
var viewer = new Cesium.Viewer('cesiumContainer'); var scene = viewer.scene;
scene.globe.depthTestAgainstTerrain = true;
var cesiumTerrainProviderMeshes = new Cesium.CesiumTerrainProvider({
url : '//assets.agi.com/stk-terrain/world',
requestWaterMask : true,
requestVertexNormals : true
viewer.terrainProvider = cesiumTerrainProviderMeshes;
// setup alternative terrain providers
var ellipsoidProvider = new Cesium.EllipsoidTerrainProvider();
var vrTheWorldProvider = new Cesium.VRTheWorldTerrainProvider({
url : '//www.vr-theworld.com/vr-theworld/tiles1.0.0/73/',
credit : 'Terrain data courtesy VT MÄK'
// Example 4: Draw an orange extruded polygon with // per position heights.
var positions = Cesium.Cartesian3.fromDegreesArrayHeights([
-108.0, 25.0, 10000,
-100.0, 25.0, 10000,
-100.0, 30.0, 10000,
-108.0, 30.0, 20000
// Set the perPositionHeight option to true for the polygon // to use the
heights each position. In this case, we are // also seting extrudedHeight to
zero for the polygon // to be extruded down to the globe surface.
var orangePolygonInstance = new Cesium.GeometryInstance({
geometry : Cesium.PolygonGeometry.fromPositions({
positions : positions,
vertexFormat : Cesium.PerInstanceColorAppearance.VERTEX_FORMAT,
perPositionHeight : true
attributes: {
color:
Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.ORANGE)
var geometryCollection = ;
geometryCollection.push(orangePolygonInstance);
var appearance = new Cesium.PerInstanceColorAppearance({
closed : true,
translucent : true
var feature = new Cesium.Primitive({
geometryInstances : geometryCollection,
allowPicking: true,
interleave : true,
appearance : appearance
scene.primitives.add(feature);
var rectangleInstance = new Cesium.GeometryInstance({
geometry : new Cesium.RectangleGeometry({
rectangle : Cesium.Rectangle.fromDegrees(-140.0, 30.0, -100.0, 40.0)
attributes : {
color : new Cesium.ColorGeometryInstanceAttribute(0.0, 1.0, 1.0, 0.5)
scene.primitives.add(new Cesium.GroundPrimitive({
geometryInstance : rectangleInstance
Sandcastle.addToolbarMenu([{
text : 'CesiumTerrainProvider - STK World Terrain',
onselect : function() {
viewer.scene.globe.enableLighting = true;
text : 'CesiumTerrainProvider - STK World Terrain - no effects',
viewer.terrainProvider = new Cesium.CesiumTerrainProvider({
text : 'CesiumTerrainProvider - STK World Terrain w/ Lighting',
text : 'CesiumTerrainProvider - STK World Terrain w/ Water',
text : 'EllipsoidTerrainProvider',
viewer.terrainProvider = ellipsoidProvider;
text : 'VRTheWorldTerrainProvider',
viewer.terrainProvider = vrTheWorldProvider;
}], 'terrainMenu');
Sandcastle.addDefaultToolbarMenu([{
text : 'Mount Everest',
var target = new Cesium.Cartesian3(300770.50872389384,
5634912.131394585, 2978152.2865545116);
var offset = new Cesium.Cartesian3(6344.974098678562,
-793.3419798081741, 2499.9508860763162);
viewer.camera.lookAt(target, offset);
viewer.camera.lookAtTransform(Cesium.Matrix4.IDENTITY);
text : 'Half Dome',
var target = new Cesium.Cartesian3(-2489625.0836225147,
-4393941.44443024, 3882535.9454173897);
var offset = new Cesium.Cartesian3(-6857.40902037546, 412.3284835694358,
2147.5545426812023);
text : 'San Francisco Bay',
var target = new Cesium.Cartesian3(-2708814.85583248,
-4254159.450845907, 3891403.9457429945);
var offset = new Cesium.Cartesian3(70642.66030209465,
-31661.517948317807, 35505.179997143336);
}], 'zoomButtons');
var terrainSamplePositions;
function sampleTerrainSuccess() {
var ellipsoid = Cesium.Ellipsoid.WGS84;
//By default, Cesium does not obsure geometry
//behind terrain. Setting this flag enables that.
//viewer.scene.globe.depthTestAgainstTerrain = true;
viewer.entities.suspendEvents();
viewer.entities.removeAll();
for (var i = 0; i < terrainSamplePositions.length; ++i) {
var position = terrainSamplePositions[i];
viewer.entities.add({
position : ellipsoid.cartographicToCartesian(position),
billboard : {
verticalOrigin : Cesium.VerticalOrigin.BOTTOM,
scale : 0.7,
image : '../images/facility.gif'
label : {
text : position.height.toFixed(1),
horizontalOrigin : Cesium.HorizontalOrigin.CENTER,
scale : 0.3,
pixelOffset : new Cesium.Cartesian2(0, -14),
fillColor : Cesium.Color.RED,
outlineColor : Cesium.Color.WHITE
viewer.entities.resumeEvents();
Sandcastle.addToolbarButton('Toggle Lighting', function() {
viewer.scene.globe.enableLighting = !viewer.scene.globe.enableLighting;
}, 'toggleLighting');
Sandcastle.addToolbarButton('Sample Everest Terrain', function() {
var gridWidth = 41;
var gridHeight = 41;
var everestLatitude = Cesium.Math.toRadians(27.988257);
var everestLongitude = Cesium.Math.toRadians(86.925145);
var rectangleHalfSize = 0.005;
var e = new Cesium.Rectangle(everestLongitude - rectangleHalfSize,
everestLatitude - rectangleHalfSize, everestLongitude + rectangleHalfSize,
everestLatitude + rectangleHalfSize);
terrainSamplePositions = ;
for (var y = 0; y < gridHeight; ++y) {
for (var x = 0; x < gridWidth; ++x) {
var longitude = Cesium.Math.lerp(e.west, e.east, x / (gridWidth -
1));
var latitude = Cesium.Math.lerp(e.south, e.north, y / (gridHeight -
1));
var position = new Cesium.Cartographic(longitude, latitude);
terrainSamplePositions.push(position);
Cesium.when(Cesium.sampleTerrain(viewer.terrainProvider, 9,
terrainSamplePositions), sampleTerrainSuccess);
}, 'sampleButtons');
var viewModel = { fogEnabled : true };
Cesium.knockout.track(viewModel);
var toolbar = document.getElementById('toolbar');
Cesium.knockout.applyBindings(viewModel, toolbar);
Cesium.knockout.getObservable(viewModel,
'fogEnabled').subscribe(function(newValue) {
viewer.scene.fog.enabled = newValue; });
viewModel.enabled = viewer.scene.fog.enabled;
//rotate the globe over the south east. When you see the orange polygon start
//zooming in. At some point the polygon will disappear. Hope this Helps Jerry
Thanks in advance
Jerry
