When I add an entity to the Viewer's EntityCollection and use a Reference Property for the new entity's position, it changes (or ignores) the definition of the ellipsoid that I am trying to create.
var availability = new Cesium.TimeIntervalCollection(<some TimeInterval>);
var position_ref = new Cesium.ReferenceProperty(viewer, 'otherId', ['position']);
viewer.entities.add({
id: 'Some Ellipsoid',
availability: availability,
position: position_ref,
ellipsoid: {
radii: new Cesium.Cartesian3(100, 200, 300),
material: Cesium.Color.RED.withAlpha(0.3),
outline: True
Then from EllipsoidGeometry.createGeometry() in CesiumUnminified/Cesium.js:
EllipsoidGeometry.createGeometry = function(ellipsoidGeometry) {
console.log(JSON.stringify(ellipsoidGeometry));
From the console log above, I would expect to see:
{"_radii":{"x":100,"y":200,"z":300},...}
But instead I see:
{"_radii":{"x":1,"y":1,"z":1},...}
The ellipsoid appears to be drawn with the correct radii, but why do I see the geometry definition like this?
If I instead use a fixed position instead of a position reference, the console log gives me what I expect. Why is that?
I need to use the geometry definition attributes from within the createGeometry function.
Cesium 1.30 on Firefox 45.1.0 on Linux (yes I know, both are old; it takes moving heaven and earth to get updates in my work environment). Note that I have a few custom mods to my local Cesium, so if you can't reproduce this it's likely I simply broke something.
