How to move multiple entities at once?
Hi there,
I’m trying to make it so that if one entity has its position updated, a separate entity also gets updated to the same position. Is this possible to do without manually changing the position value of the second entity?
Thanks!
In CZML you can use a Reference to indicate that one property’s value should point to another property.
https://github.com/AnalyticalGraphicsInc/czml-writer/wiki/ReferenceValue
In the Cesium Entity layer this corresponds to a ReferenceProperty: https://cesiumjs.org/Cesium/Build/Documentation/ReferenceProperty.html
Alternatively, in the Entity layer in JavaScript you can just assign the same Property object to two different entities.
