I add satellite orbit from a czml file, and add cylinder under each satellite using the entity’s position CallbackProperty. But when there is more than one satellite in czml file, the function only render the last satellite’s cylinder in czml file, please help…
var dataSource = new Cesium.CzmlDataSource();
dataSource.process(‘./SampleData/satellite1.czml’).then(function() {
console.log(dataSource.entities.values.length);
var saEntity;
var nowPos = ;
for(var i=0;i<dataSource.entities.values.length;i++){
saEntity = dataSource.entities.values[i];
var isConstant = false;
var tmp = i;
viewer.entities.add({
position : new Cesium.CallbackProperty(function(time) {
nowPos[i] = Cesium.Ellipsoid.WGS84.cartesianToCartographic(saEntity.position.getValue(time));
console.log(tmp + “:” + time);
//if(i==0){ console.log(tmp + “:”+ time + “pos:” + nowPos[i]); }
return Cesium.Cartesian3.fromDegrees(Cesium.Math.toDegrees(nowPos[i].longitude),Cesium.Math.toDegrees(nowPos[i].latitude),0,Cesium.Ellipsoid.WGS84);
}, isConstant),
cylinder: {
length: new Cesium.CallbackProperty(function(time) {
return nowPos[i].height;
}, isConstant),
topRadius: 0.0,
bottomRadius: 300000.0,
material: Cesium.Color.RED.withAlpha(0.2),
cesium 1.51 ,chrome 70
