This is likely my not understanding javascript very well, but I can't figure out how to reference a viewer instance that was created and returned from a separate script. What I would like to do is have an initialization script that creates a viewer and a few methods. One method would be to add a satellite. Then in a separate script be able to toggle on / off the visibility of any entities in that viewer. I can't seem to be able to reference that viewer or the entities added to it from another script.
After calling the app.initCesium() method below, I thought I should be able to reference the viewer via app.viewer, but that doesn't work. Any help or further reading would be appreciated. Thanks in advance.
var app = (function () {
var _viewer = {};
var _initCesium = function () {
_viewer = new Cesium.Viewer('cesiumContainer',
// Exercise #1
var _addSatellite = function () {
var stopDate = \('\#startDate'\)\[0\]\.valueAsDate;
stopDate\.setDate\(stopDate\.getDate\(\) \+ 1\);
// create json post data for the service
var postData = \{
Start: ('#startDate').val() + "T00:00:00Z",
Stop: stopDate.toISOString(),
SSC: \('\#sscNumber'\)\.val\(\),
PathColor: ('#pathColor').val(),
SatelliteName: \('\#sscNumber'\)\.val\(\),
OutputSettings: \{
Step: "900",
TimeFormat: "Epoch",
CoordinateFormat:\{
Coord: "XYZ",
Frame: "Inertial"
// call STK Analytical Services \(using jQuery ajax call\)
.ajax({
url: "https://saas.agi.com/V1/vehiclePath/czml/sgp4?u=RPC3D3vVaFogiwFO",
type: "POST",
data: postData,
success: function (result,status){
addCzmlDataSource(result);
error: function(error){
alert(error.responseText);
return {
initCesium: _initCesium,
addSatellite: _addSatellite,
viewer: _viewer
