Hi!
I have a problem with registering/unregistering event handlers in Cesium, and I can’t seem to disable a previously registered event handler. All event handlers are stored on app initialization. Code:
I have a function which registers an event handler on LEFT_CLICK
const toggleAddListener = async (
scene: Scene,
screenSpaceEventHandler: ScreenSpaceEventHandler
): Promise<void> => {
const viewer = useCesiumViewer();
removeAllScreenSpaceInputActions(viewer, screenSpaceEventHandler);
if(shouldBeRegistered)
screenSpaceEventHandler.setInputAction(async (event: { position: Cartesian2 }) => {
//Code emitted, actions here
}, ScreenSpaceEventType.LEFT_CLICK);
} else {
OriginalCesiumInputActions.LEFT_CLICK,
This function works just fine and achieves what I want. But we need to be able to disable this event handler outside this function in several cases. So we made a function which removes and resets all handlers that are used.
const removeAllScreenSpaceInputActions = (
viewer: Viewer,
if (!screenSpaceEventHandler) return;
screenSpaceEventHandler.removeInputAction(
ScreenSpaceEventType.MOUSE_MOVE,
KeyboardEventModifier.SHIFT
ScreenSpaceEventType.LEFT_CLICK,
ScreenSpaceEventType.RIGHT_CLICK,
screenSpaceEventHandler.removeInputAction(ScreenSpaceEventType.MOUSE_MOVE);
screenSpaceEventHandler.removeInputAction(ScreenSpaceEventType.LEFT_CLICK);
screenSpaceEventHandler.removeInputAction(ScreenSpaceEventType.RIGHT_CLICK);
screenSpaceEventHandler.removeInputAction(ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
screenSpaceEventHandler.removeInputAction(ScreenSpaceEventType.LEFT_DOWN);
screenSpaceEventHandler.removeInputAction(ScreenSpaceEventType.LEFT_UP);
screenSpaceEventHandler.setInputAction(() => ({}), ScreenSpaceEventType.LEFT_DOWN);
/* screenSpaceEventHandler.setInputAction(
OriginalCesiumInputActions.LEFT_DOWN,
if (
OriginalCesiumInputActions.LEFT_CLICK__SHIFT &&
OriginalCesiumInputActions.RIGHT_CLICK__SHIFT &&
OriginalCesiumInputActions.LEFT_CLICK__SHIFT,
OriginalCesiumInputActions.RIGHT_CLICK__SHIFT,
viewer.scene.screenSpaceCameraController.enableTranslate = true;
viewer.scene.screenSpaceCameraController.enableLook = true;
This does not work, and the event handler in my first snippet still triggers after a full reset. FYI:
- I tried limiting removeAllScreenSpaceInputActions to only contain LEFT_CLICK to mirror the else-block which works, but still no success.
- I’ve debugged and logged the events, and everything happens in the correct order.
- The functions run from the same script, so there is no framework lifecycle interfering.
I’m new here, so tell me if you need more information about the problem ![]()
