I would like to render my tileset using cesiumjs. The tileset url requires an access token to fetch the tileset.json file from the container.
In the past I have used code like this to render my tilesets:
const tilesetUrl = 'https://example.cloudfront.net/1234/tileset.json?sv=2024-05-04&spr=https&se=2024-11-09T23%3A59%3A59Z&sr=c&sp=rl&sig=<token>&Signature=<sig>';
const tileset = await Cesium3DTileset.fromUrl(tilesetUrl);
That works fine when the tilesetUrl does not require authentication. Can I use this same method to render a tileset Url which requires passing an accessToken as the Authorization header while fetching?
