I am trying to load a 3dtile from a object instead of a url. The object structure would be the same as the object/json in the tileset.json file but with some changes. For example, I would like to use
cesiumViewer.scene.primitives.add(new Cesium.Cesium3DTileset({
url: url,
but instead of url, I would like to pass in an object. Is this possible?
The reason why I want to do this is because I want to first fetch the tileset.json and then edit out a child in the tileset.json file and then load that newly edited tileset.json file. I am trying to do this but there was no solution in that thread. I know I can edit the tileset.json file before hand but I need to do it on the fly. The tileset contains 1000+ children so I cannot split them and load them separately because that would be very slow.
