Hii, yes I’ve attached the code to this post, and no. when I debug cesium itself I can see that each instance of the drawcommand had a different color.
export class EllipsePrimitive {
private _center: any;
private _semiMajor: number;
private _semiMinor: number;
private _rotation: number;
private _show: boolean;
private _material: any;
private _modelMatrix: any;
private _renderState;
private _drawCommand;
private _points;
private _indexBufferArray;
private _indicesArray;
private _dirty = true;
private _lastMode;
private _color;
private vertexArray;
private _shaderProgram;
constructor(options: {center: any, semiMajorAxis: number, semiMinorAxis: number, rotation?: number, show?: boolean, color?:number[]}) {
this._center = Cesium.Cartesian3.clone(options.center);
this._semiMajor = options.semiMajorAxis;
this._semiMinor = options.semiMinorAxis;
this._rotation = options.rotation || 0;
this._show = options.show || true;
this._material = Cesium.Material.fromType(Cesium.Material.ColorType);
this._modelMatrix = Cesium.Matrix4.clone(Cesium.Matrix4.IDENTITY);
this._drawCommand = new Cesium.DrawCommand({owner: this});
this._color = options.color || [0.0, 0.0, 0.0, 1.0];
this.calculatePoints();
get center(): any {
return this._center;
set center(value: any) {
if (this._center !== value) {
this._center = value;
this._dirty = true;
private set points(value) {
if (!this._indexBufferArray || (this._points && this._points.outerPositions && this._points.outerPositions.length !== value.outerPositions.length)) {
this._indicesArray = EllipsePrimitive.createIndicesArray(value.outerPositions.length);
this._points = value;
updateLocationData(data: {center?, semiMajorAxis?: number, semiMinorAxis?: number, rotation?: number}) {
this.center = data.center || this._center;
update(frameState) {
if (!this._show) {
return;
let context = frameState.context;
this.vertexArray = (this._dirty || !this.vertexArray) ? this.createVertexArray(context) : this.vertexArray;
this.setupShaderProgram(context);
this.setupRenderState();
this.setupDrawCommand();
frameState.commandList.push(this._drawCommand);
private sceneModeChanged(mode: number) {
return this._lastMode !== mode;
private createVertexArray(context: any) {
this._dirty = false;
let vertexBuffer = Cesium.Buffer.createVertexBuffer({
context: context,
typedArray: new Float32Array(this._points.outerPositions),
usage: Cesium.BufferUsage.STATIC_DRAW
let attributes = [
index: 0,
enabled: true,
vertexBuffer: vertexBuffer,
componentsPerAttribute: 3,
componentDatatype: Cesium.ComponentDatatype.FLOAT,
normalize: false,
offsetInBytes: 0,
strideInBytes: 0
index: 1,
enabled: true,
value: this._color,
componentsPerAttribute: 4,
normalize: false,
offsetInBytes: 0,
strideInBytes: 0
return new Cesium.VertexArray({
context: context,
attributes: attributes,
indexBuffer: this.createIndexBuffer(context)
private setupShaderProgram(context: any) {
this._shaderProgram = this._shaderProgram || Cesium.ShaderProgram.replaceCache({
context: context,
shaderProgram: this._shaderProgram,
vertexShaderSource: `
attribute vec3 position;
attribute vec4 color;
varying vec4 v_color;
void main() {
gl_Position = czm_modelViewProjection * vec4(position, 1.0);
v_color = color;
fragmentShaderSource: `
void main()
gl_FragColor = v_color;
private setupRenderState() {
this._renderState = Cesium.RenderState.fromCache({
cull: {
enabled: true,
face: Cesium.CullFace.FRONT
depthTest: {
enabled: false
depthMask: true,
blending: undefined
private setupDrawCommand() {
this._drawCommand.modelMatrix = this._modelMatrix;
this._drawCommand.renderState = this._renderState;
this._drawCommand.primitiveType = Cesium.PrimitiveType.LINE_LOOP;
this._drawCommand.shaderProgram = this._shaderProgram;
this._drawCommand.vertexArray = this.vertexArray;
this._drawCommand.pass = Cesium.Pass.OPAQUE;
this._drawCommand.boundingVolume = this.createBoundingVolume();
this._drawCommand.debugShowBoundingVolume = false;
private calculatePoints() {
this.points = Cesium.EllipseGeometryLibrary.computeEllipsePositions({
center: this._center,
rotation: this._rotation,
semiMajorAxis: this._semiMajor,
semiMinorAxis: this._semiMinor,
granularity: 0.03
}, false, true);
private createIndexBuffer(context) {
this._indexBufferArray = Cesium.Buffer.createIndexBuffer({
context: context,
typedArray: this._indicesArray,
usage: Cesium.BufferUsage.STATIC_DRAW,
indexDatatype: Cesium.IndexDatatype.UNSIGNED_SHORT
private static createIndicesArray(size: number) {
let indicesArray = [];
for (let i = 0; i < size / 3; i++) {
indicesArray.push(i);
return new Uint16Array(indicesArray);
private createBoundingVolume() {
return new Cesium.BoundingSphere(this._center, this._semiMajor);
private createInnerIndexBuffer(context: any) {
for (let i = 1; i < this._points.positions.length / 3; i++) {
indicesArray.push(i - 1);
indicesArray.push(i + 1);
return Cesium.Buffer.createIndexBuffer({
context: context,
typedArray: new Uint16Array(indicesArray),
