Revit, Forma, Twinmotion and Enscape
Is there any workflow for using the 3D tiles with Revit, Autodesk Forma, Twinmotion, and Enscape?
I know it works in Unreal, but not many Architects have experience in Unreal.
Is there any option to import the tiles inside Revit, Forma or Twinmotion?
When you ask about using 3D Tiles, then it not clear what exactly this refers to. 3D Tiles is mainly intended for efficiently streaming data to clients, so I cannot imagine what a general mechanism for importing that into authoring applications should look like.
But it is possible to export data from such applications and then convert it to 3D Tiles. This can happen via common interchange formats, and in some cases, the export is also directly integrated into the authoring application via plugins. For example, for Revit, there is Cesium ion for Autodesk Revit Quickstart – Cesium
