hi,I am working on cesium flight simulator and I just wanted to run my final code without going into sandcastle.for example if user have to see the model then he should just double click on a html or any file that contains cesium code. can you help me with this?
Take a look at our Getting Started tutorial: http://cesiumjs.org/tutorials/cesium-up-and-running/
That will show you how to run a stand-alone Hello World application.
Hannah
Hi Hannah,
Thank you for the guidance. I have already solved that problem. I was having problem with webgl and was not using the *.html file properly that was created by the final code.
Thanks.
