When I run this code:
var geocoder = viewer.geocoder.viewModel;
geocoder.searchText = 'Spain';
geocoder.flightDuration = 0.5;
geocoder.search();
The search window is open with text "Spain"... there's an option to hidde this text window to user?
I use keepExpanded=false but box text still open...
Thanks
Generally the main purpose of the view models is to programmatically control the user interface. If you just want to do a background geocode without affecting the user interface, you could simply use the underlying GeocoderService directly by calling geocode, then take the first result and call flyTo.
https://cesiumjs.org/Cesium/Build/Documentation/GeocoderService.html
https://cesiumjs.org/Cesium/Build/Documentation/Camera.html#flyTo
Hello Scott Hunter
Do you have an example, please?
Thanks
var geocoderService = new Cesium.IonGeocoderService({
scene: viewer.scene
geocoderService.geocode(‘spain’).then(function(result){
if (Cesium.defined(result) && Cesium.defined(result[0])) {
console.log(result[0].destination);
viewer.camera.flyTo({
destination : result[0].destination
