What’s a way to get a line like this? Such that it can be rendered from the current location to the ground? Ideally with fading out
Hi @scottyob, welcome to the community!
One way would be with PolylineGraphics. See the Custom Data Source Sandcastle.
const color = Cesium.Color.fromHsl(0.6 - height * 0.5, 1.0, 0.5);
const surfacePosition = Cesium.Cartesian3.fromDegrees(
longitude,
latitude,
0
const heightPosition = Cesium.Cartesian3.fromDegrees(
longitude,
latitude,
height * heightScale
//WebGL Globe only contains lines, so that's the only graphics we create.
const polyline = new Cesium.PolylineGraphics();
polyline.material = new Cesium.ColorMaterialProperty(color);
polyline.width = new Cesium.ConstantProperty(2);
polyline.arcType = new Cesium.ConstantProperty(
Cesium.ArcType.NONE
polyline.positions = new Cesium.ConstantProperty([
surfacePosition,
heightPosition,
//The polyline instance itself needs to be on an entity.
const entity = new Cesium.Entity({
id: `${seriesName} index ${i.toString()}`,
show: show,
polyline: polyline,
seriesName: seriesName, //Custom property to indicate series name
Thanks so much, @jjhembd!
I’m struggling to try and get this to move with my path in czml though. Any pointers?
let timeInterval = fixToTime(flight.fixes[0]) + "/" + fixToTime(flight.fixes.slice(-1)[0]);
// Build the czml document
const czml: any = [
version: "1.0",
clock: {
interval: timeInterval,
currentTime: fixToTime(flight.fixes[0])
name: "Path with GPS Flight data",
position: {
epoch: fixToTime(flight.fixes[0]),
cartographicDegrees: createCzmlPath(flight.fixes)
path: {
show: true,
leadTime: 0,
trailTime: 60,
width: 2.5,
resolution: 1,
material: {
polylineGrow: {
glowPower: 0.3,
taperPower: 0.3,
color: { rgba: [255, 0, 0, 255] }
point: {
eyeOffset: {
cartesian: [0.0, 0.0, -10.0],
I’ve given it a go, but I think I’m missing something: GitHub - scottyob/react-igc: React component for rendering IGC files
It appears my Polyline is being drawn through the terrain. I’ve chucked my code up at GitHub - scottyob/react-igc: React component for rendering IGC files if you’d be so kind as to take a look
Solution was fairly simple:
// Enable depth testing
viewer.scene.globe.depthTestAgainstTerrain = true;
