I have just started using ***SampledProperty ***a few days ago thanks to Matthew.
I’ve found some erros in the documentation, as well as huge gaps as to how to use these features.
The example at the ***VelocityOrientationProperty *** has an error.
It calls:var position = new Cesium.SampledProperty();``
Which returns an error since SampledProperty expects a type.
What are the derivatives mentioned in ***SampledProperty ***? How can one use them?
Why should I use SampledPositionProperty and not SampledProperty(Cesium.Cartesian3)?
When I try the example from SampledProperty for material, it doesn’t work. It works for outline color, but not for material color. I’ve tried several ways, but all resulted in a certain error. Here’s one code I thought might work, but it doesn’t:
// Datesvar date = new Date();
var jDate = new Cesium.JulianDate.fromDate(date);
//Create a material sampled property
var materialProperty = new Cesium.SampledProperty(Cesium.ColorMaterialProperty);
//Populate it with data
materialProperty.addSample(jDate, new Cesium.ColorMaterialProperty(Cesium.Color.RED)); //throws an error
Or if I try a different one like this:
//Create a color sampled property
var colorProperty = new Cesium.SampledProperty(Cesium.Color);
colorProperty.forwardExtrapolationType = Cesium.ExtrapolationType.HOLD;
colorProperty.addSample(jDate, Cesium.Color.RED);
colorProperty.addSample(nextJDate, Cesium.Color.BLUE);
var redEllipse = viewer.entities.add({
position: positionProperty,
name : ‘Red ellipse on surface with outline’,
ellipse : {
semiMinorAxis : 250000.0,
semiMajorAxis : 400000.0,
material : colorProperty,
outline : true,
outlineColor : colorProperty
Would also throw an error for the material (if I just add a regular *Color *to the material, it does work… but not with a sampled one).
Would appreciate some light shed over this one (and maybe an improvement to the docs would arise from this post…).
