When cesium comes up it already has a bunch of layers defined. Is there a simple way to programmatically change the layers used?
It would seem there’s a mechanism to select an already existing definition by an index or such.
v/r
Ken J.
v/r
Ken J.
Hello Ken,
Are you trying to programatically select a layer from the base layer picker widget? Here is code to accomplish that:
var baseLayerPickerViewModel = viewer.baseLayerPicker.viewModel;
baseLayerPickerViewModel.selectedImagery = baseLayerPickerViewModel.imageryProviderViewModels[3];
Hannah
Again, THANK YOU Hannah. Some of this stuff isn’t obvious from the documentation and a quick questions save lots of time.
v/r
Ken
