I have created a series of stacked polygons, right next to each other, as per their latitude and longitude. I would expect these to have their edges touching each other. However, they are separate.
As discussed in http://gis.stackexchange.com/questions/191984/openlayers-3-cesium-polygon-projection-issue , the issue is that vertices are defined using latitude and longitude, whereas polygons are drawn in a different projection.
Is there a way to tell Cesium the projection to use for rendering a polygon? Otherwise, is this something that could be added in the future?
(which we could document in a GitHub artefact).
Code used in the sandcastle:
