Selection Indicator keeps pointing to top left of screen after clicking entity
I created a billboard entity in the cesium globe. When I clicked it, the selection indicator should point straight at the entity but instead, it pointed slightly to the top left corner of the screen. The selection indicator keeps pointing at the same position even when i rotate the globe a bit and re-click the entity. Anyone has any similar problem?
Regards
Calvin Chua
Hello Calvin,
Can you paste a code sample that causes this to happen? I’m guessing something is unusual about your page CSS styling. Did you change any of the Cesium default CSS? The selection indicator is positioned using absolute positioning.
-Hannah
