I don’t understand why it gives error in the following snippet.7
error:Cesium.SensorVolumeCollection is not a constructor at
var sensors = new Cesium.SensorVolumeCollection();
omar
July 8, 2019, 1:30pm
#2
The SensorVolumeCollection doesn’t appear to be a valid class. Did you see it in a code example somewhere? What version of CesiumJS are you using?
omar
July 8, 2019, 2:43pm
#4
Looks like that version is about 5 years old at this point! I would make sure to reference the current documentation when debugging this: https://cesiumjs.org/Cesium/Build/Documentation/
The sensors/analytics have been moved into the ion SDK https://cesium.com/ion-sdk/ which you can currently get an enterprise license to use. We’re planning on adding it as part of the Cesium ion platform sometime soon so it’s available to more users.
