Hello, I am now working on uploading thousands of obj files to cesium ion. However, I found that I have to set the tileset location via “Cesium ion”. Are there any methods to do this via rest API / programmatically?
Hi Nick, Good question. The assests can be positioned via the API with Cesium JS like in the Sandcastle. I jhave yet to find a way to set it in Cesium ION.
If you find how to update ION asset location please share.
Thank you, Steve. I have stopped trying cesium ion and developing an alternative solution to show the 3d models effectively. I will still give it a try after office hours if I have enough time.
Note that it’s a bit hidden – you first have to select a data type. If you select [3D_CAPTURE] from the dropdown, you will finally see additional input fields including position.
