Hi Josef,
I looked at your CZML and found a couple of problems. There are "null"s for height
I don’t see any times so you won’t be able to use PathGraphics. Additionally, it is necessary to use a separate entity for each waypoint.
Here’s some of the CZML I put together from your data:
“id”: “document”,
“name”: “Hike”,
“version”: “1.0”
“id”: “point 0”,
“name”: “point”,
“position”: {
“cartographicDegrees”: [11.864392, 47.675069, 0]
“point”: {
“color”: {
“rgba”: [255, 255, 255, 200]
“outlineWidth”: 5,
“outlineColor”: {
“rgba”: [0, 173, 253, 200]
“pixelSize”: 10
“id”: “path”,
“position”: {
“polyline”: {
“positions”: {
“cartographicDegrees”: [11.864392, 47.675069, 0, 11.863748, 47.675036, 0, 11.863384, 47.675047, 0, 11.863008, 47.675072, 0, 11.86281, 47.674993, 0, 11.862348, 47.675014, 0, 11.860825, 47.676513, 0, 11.860642, 47.676369, 0, 11.860487, 47.676304, 0, 11.86038, 47.6763, 0, 11.860283, 47.676257, 0, 11.860149, 47.676344, 0, 11.860052, 47.676322, 0, 11.859977, 47.676362, 0, 11.859875, 47.676481, 0, 11.859645, 47.676477, 0, 11.859414, 47.676513, 0, 11.859253, 47.676737, 0, 11.85928, 47.676802, 0, 11.858904, 47.676752, 0, 11.858502, 47.676528, 0, 11.85825, 47.676459, 0, 11.858175, 47.676495, 0, 11.858009, 47.676499, 0, 11.857708, 47.676409, 0, 11.857612, 47.676445, 0, 11.857424, 47.676394, 0, 11.856914, 47.675975, 0, 11.85641, 47.675776, 0, 11.856206, 47.675632, 0, 11.855729, 47.675484, 0, 11.855568, 47.675368, 0, 11.855471, 47.675224, 0, 11.855407, 47.674827, 0, 11.855686, 47.674621, 0, 11.855755, 47.674487, 0, 11.855906, 47.674339, 0, 11.85597, 47.674212, 0, 11.856378, 47.673942, 0, 11.856726, 47.673663, 0, 11.856984, 47.673046, 0, 11.857021, 47.672807, 0, 11.857016, 47.672443, 0, 11.856925, 47.672244, 0, 11.856657, 47.671908, 0, 11.856426, 47.671774, 0, 11.856104, 47.67172, 0, 11.856008, 47.671659, 0, 11.856265, 47.671453, 0, 11.856533, 47.671391, 0, 11.856673, 47.671377, 0, 11.85678, 47.671348, 0, 11.856249, 47.671095, 0, 11.85575, 47.670918, 0, 11.855455, 47.670716, 0, 11.855058, 47.670532, 0, 11.85465, 47.670568, 0, 11.854366, 47.670445, 0, 11.854189, 47.670286, 0, 11.853985, 47.670203, 0, 11.853755, 47.670127, 0, 11.853744, 47.669921, 0, 11.85258, 47.669441, 0, 11.852033, 47.668996, 0, 11.851861, 47.668686, 0, 11.851861, 47.668552, 0, 11.851507, 47.668223, 0, 11.851416, 47.668184, 0, 11.851357, 47.668039, 0, 11.851421, 47.667952, 0, 11.8514, 47.667913, 0, 11.851303, 47.668028, 0, 11.851383, 47.668212, 0, 11.851485, 47.668252, 0, 11.851818, 47.668552, 0, 11.851823, 47.668696, 0, 11.851963, 47.668989, 0, 11.852537, 47.669462, 0, 11.85369, 47.669936, 0, 11.853738, 47.670163, 0, 11.853974, 47.670203, 0, 11.853808, 47.670358, 0, 11.855063, 47.671305, 0, 11.855493, 47.671518, 0, 11.856024, 47.671644, 0, 11.856126, 47.671709, 0, 11.856437, 47.671767, 0, 11.856662, 47.671893, 0, 11.856946, 47.672251, 0, 11.857188, 47.672591, 0, 11.857241, 47.673494, 0, 11.857359, 47.673559, 0, 11.858003, 47.673197, 0, 11.858282, 47.673169, 0, 11.858234, 47.673313, 0, 11.858384, 47.673299, 0, 11.858475, 47.673371, 0, 11.858829, 47.673302, 0, 11.858958, 47.673317, 0, 11.858979, 47.673479, 0, 11.859215, 47.673497, 0, 11.859173, 47.673877, 0, 11.859527, 47.673848, 0, 11.86016, 47.673898, 0, 11.860235, 47.673999, 0, 11.860707, 47.673978, 0, 11.861082, 47.674064, 0, 11.861608, 47.674028, 0, 11.861812, 47.674137, 0, 11.861941, 47.674592, 0, 11.862112, 47.674924, 0, 11.862359, 47.674996, 0, 11.862842, 47.674967, 0, 11.863003, 47.675047, 0, 11.863754, 47.675004, 0, 11.864387, 47.67504, 0]
“clampToGround”: true,
“width”: 6,
“material”: {
“polylineOutline”: {
“color”: {
“outlineWidth”: 5,
“outlineColor”: {
“resolution”: 5
{ “id”: “point 0”, “position”: { “cartographicDegrees”: [11.864392, 47.675069, 30] }, “point”: { “pixelSize”: 3, “heightReference”: “RELATIVE_TO_GROUND” } },
{ "id": "point 115", "position": { "cartographicDegrees": [11.864387, 47.67504, 30] }, "point": { "pixelSize": 3, "heightReference": "RELATIVE_TO_GROUND" } }
Hope that helps.
Scott
