Images from other billboards showing up when setting the imageSubRegion on a billboard. The image is attached. The last two images on the last row look to cause the billboard to be transparent. Is there a known bug about this? Or is there a better way to do this? This works really well but occasionally images outside of the attached photo are appearing? Maybe I’m stepping off the bounds?
cesium.entities.add( new Cesium.Entity( {
“position”: targetLocation,
“billboard”: {
//“image”: “images/explosion.png”,
“image”: FileLoader.getImage( “explosion” ).image,
“imageSubRegion”: new Cesium.CallbackProperty( function( time, result ) {
msg.imageInfo.rect.x = msg.imageInfo.x();
msg.imageInfo.rect.y = msg.imageInfo.y();
return msg.imageInfo.rect;
}, false ),
“show”: true,
“eyeOffset”: new Cesium.Cartesian3( 0.0, 0.0, -2*UNIT_DIMENSIONS ),
“scale”: 1.0,
“width”: 2 * UNIT_DIMENSIONS,
“height”: 2 * UNIT_DIMENSIONS
To show a 2D explosion on a billboard.
Cesium: 1.36
Windows 7 Enterprise
**Chrome **Version 60.0.3112.113 (Official Build) (64-bit)
