Hi All
May be a studif question but I new to Cesium and didnt find an answer searching the forum....
I try to create a custom geometry, actually just draw a line but not using entities.add but using a geometry. I try following simple code in Sandcastle:
var scene = viewer.scene;
var polyline = new Cesium.PolylineGeometry({
positions : Cesium.Cartesian3.fromDegreesArray([-75, 35, -125, 35]),
width : 10.0,
color : [Cesium.Color.RED],
var instance = new Cesium.GeometryInstance({geometry : polyline});
scene.primitives.add(new Cesium.Primitive({
geometryInstances : [instance]
From what I studied from documentation and tutorials, this should work. But its not (line is not showing).....
What am I doing wrong?
Windows 7, Chrome
Hi there,
- You need to set the primitive appearance to use that color:
appearance : new Cesium.PolylineMaterialAppearance({
material : Cesium.Material.fromType('Color')
- Since there are no entities added to the scene, you can’t have the viewer zoom to them. You’ll have to set the camera position based on your positions:
Enter code here…viewer.camera.setView({
destination : Cesium.Cartesian3.fromDegrees(-100, 35, 10000000.0)
Here’s a full working example:
var positions = Cesium.Cartesian3.fromDegreesArray([
-75, 35,
-125, 35
positions : positions,
width : 10.0,
geometryInstances : [instance],
material : Cesium.Material.fromType(‘Color’)
Thanks!
Gabby
Hi Gaby
Thanks for the answer.
It works, but when I change color (for example to Cesium.Color.BLUE), the line is still red. Looks like "colors" geometry attribute is ignored (btw, it should be colors, not color, right?).
My mistake!
Here’s a working geometry:
width : 10.0,
vertexFormat : Cesium.PolylineColorAppearance.VERTEX_FORMAT
geometry : polyline,
attributes : {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.CYAN)
appearance : new Cesium.PolylineColorAppearance({
translucent : false
