Using Ed Mackey’s Sun model program as a base: https://gist.github.com/emackey/53f4db126209bb590821
I’ve added all the planets of our Solar System. The sizes are to scale. If you increase the simulation speed you can watch them geo-synchronously revolve around the Earth at the same distance as Earth’s Moon.
Of course this is just a simple crude mock-up, and of course planets don’t revolve around the Earth! However being at the same distance as the Earth’s Moon does give a good sense of their size. The Sun is shown at 1 GigaMeter from the Earth (rather than it’s usual 150 GigaMeters) and is fixed in place. I was thinking of modifying it further making all of the planets orbit the Sun and in the proper order, but making the orbit distance much lower than in actuality so one can easily see all of the planets from one viewpoint. Also convert to entities, the label property on primitives didn’t seem to do anything.
If Simon1994PlanetaryPositions had all of the planets I suppose one could make the entire Solar System to scale in every way.
copy/paste to SandCastle
viewer.scene.camera.frustum.far = 1e12; //Move the far wall of the viewing frustum.
var scene = viewer.scene;
scene.skyBox.show = true;
scene.sun.show = false;
scene.globe.enableLighting = true;
var moonDistance = 384e6;var i;var center;
var sunN=0;var merN=1;var venN=2;var earN=3;var marN=4;
var jupN=5;var satN=6;var uraN=7;var nepN=8;
var radius = [
6.955e8 /Sun/
,2440000 /Mercury/
,6052000 /Venus/
,6371000 /Earth/
,3390000 /Mars/
,69911000 /Jupiter/
,58232000 /Saturn/
,25362000 /Uranus/
,24622000 /Neptune/
var color = [
Cesium.Color.fromCssColorString(’#FFFF00’) /Sun/
,Cesium.Color.fromCssColorString(’#444444’) /Mercury/
,Cesium.Color.fromCssColorString(’#EEEEEE’) /Venus/
,Cesium.Color.fromCssColorString(’#0000FF’) /Earth/
,Cesium.Color.fromCssColorString(’#FF8800’) /Mars/
,Cesium.Color.fromCssColorString(’#CC3333’) /Jupiter/
,Cesium.Color.fromCssColorString(’#D1B546’) /Saturn/
,Cesium.Color.fromCssColorString(’#6DB7A6’) /Uranus/
,Cesium.Color.fromCssColorString(’#71BEE5’) /Neptune/
var angle = [
0 /Sun/
,0 /Mercury/
,15 /Venus/
,0 /Earth/
,30 /Mars/
,45 /Jupiter/
,60 /Saturn/
,75 /Uranus/
,90 /Neptune/
var mat=;var pri=;
i=0;while(i<9)
if(i==earN){i+=1;continue;}
mat[i]=Cesium.Material.fromType(Cesium.Material.RimLightingType);
mat[i].uniforms.color=color[i];
if(i == sunN){center=Cesium.Cartesian3();}else
{center=new Cesium.Cartesian3(moonDistanceMath.cos(angle[i]),moonDistanceMath.sin(angle[i]),0);}
pri[i]=scene.primitives.add(new Cesium.EllipsoidPrimitive(
center:center
,radii:new Cesium.Cartesian3(radius[i], radius[i], radius[i])
,material:mat[i]
i+=1;
//The rest is unmodified from Ed Mackey’s Sun program (except the {x:1000000000,y:0,z:0} )
// Allocate “new” variables outside of the render loop when possible, to reduce garbage collection.
var sunPosition = new Cesium.Cartesian3();
var icrfToFixedScratch = new Cesium.Matrix3();
var sunModelMatrixScratch = new Cesium.Matrix4();
// Update the camera and the Sun with each animation frame.
function icrf(scene, time) {
if (scene.mode !== Cesium.SceneMode.SCENE3D) {
return;
var icrfToFixed = Cesium.Transforms.computeIcrfToFixedMatrix(time, icrfToFixedScratch);
if (Cesium.defined(icrfToFixed)) {
// Update the camera with the new ICRF rotation
scene.camera.transform = Cesium.Matrix4.fromRotationTranslation(icrfToFixed);
// Compute Sun position in Inertial.
Cesium.Simon1994PlanetaryPositions.computeSunPositionInEarthInertialFrame(time, sunPosition);
// Transform Sun position from Inertial to Fixed.
Cesium.Matrix3.multiplyByVector(icrfToFixed, {x:1000000000,y:0,z:0}, sunPosition);
// Update the Sun’s modelMatrix to move it from the origin to its new position for this animation frame.
pri[sunN].modelMatrix = Cesium.Matrix4.fromRotationTranslation(Cesium.Matrix3.IDENTITY, sunPosition, sunModelMatrixScratch);
scene.preRender.addEventListener(icrf);
