Cesium has changed packaging and directory structure
This becomes very incomprehensible
I can only package it out to see my modification results
How can I use source code debugging, like before?
Hi @shuidiBeida,
Can you describe your current debugging setup? Are you using source code from GitHub, an npm package, or a zipped release?
I don’t want to pack
In the previous old version, I can directly use the source code for debugging
But now, I have to pack
Let me give an example:
How can I run Sandcastle’s demo using source code instead of packaged Cesium. js?
Thank you very much for your reply!
The purpose of doing this is to better use source code debugging
But currently, I don’t seem to be able to find a solution for the latest version
