Hi!
I believe (not sure) that someone said it's better to use the source of Cesium for debugging purposes (rather than the obfuscated build results).
How can I do it?
I tried to use the sources of Cesium 1.8 instead of the normal Cesium.js, plus adding the dependencies at the start of the HTML file:
<script src="js/Cesium-dependencies/dojo-release-1.9.3/dijit/dijit.js"></script>
<script src="js/Cesium-dependencies/es5-shim/es5-sham.js"></script>
<script src="js/Cesium-dependencies/es5-shim/es5-shim.js"></script>
<script src="js/Cesium-dependencies/jasmine-2.2.0/jasmine.js"></script>
<script src="js/Cesium-dependencies/jshint-2.1.10/jshint.js"></script>
<script src="js/Cesium-dependencies/requirejs-2.1.9/require.js"></script>
<script src="js/Cesium-1.8-src/Cesium.js"></script>
But it didn't work.
What is the right way to use a non-obfuscated version of Cesium for debugging purposes?
Thanks in advance
Dmitri Pisarenko
