Hello I'm trying to create a static grid system on the globe with exact longitude and latitude lines. I want two options for the grid. One display with 1 unit square of measure, and another with .1 unit square of measure. At first I tried making polylines to cover the globe. The measurements were perfect, but the problem it led me was that the frame rate was terrible when I went to the .1 measurements.
Then I tried making an ellipsoid to cover the globe instead. This helped performance by a lot, but I encountered the problem with my Longitude being correct, but my Latitudes were off. I would of used the GridImageryProvider unfortunately this class isn't helpful because it dynamically renders, and doesn't stay at the measurements needed.
Ellipsoid example
Action listener for partition settings.
gridSlicePartitions is set to 360 for one quit of measure, and 3600 for .1
gridStackPartitions are set to 180 and 1800
gridDisplay = viewer.entities.add({
position: new Cartesian3(),
ellipsoid : {
radii : viewer.scene.globe.ellipsoid.radii,
fill : false,
outline : true,
outlineColor : Cesium.Color.GREEN.withAlpha(0.25),
slicePartitions : gridSlicePartitions,
stackPartitions : gridStackPartitions
With the PolyLines I tried making multiple PolylineCollection()'s to help with performance, but didn't help me as much.
// .1 measurement function for polylines
function createGreaterGrid(){
polyLinesLon1 = new Cesium.PolylineCollection();
polyLinesLon2 = new Cesium.PolylineCollection();
polyLinesLat2 = new Cesium.PolylineCollection();
polyLinesLat1 = new Cesium.PolylineCollection();
var line = ;
for(var x = -90; x <= 90; x+=0.1){
for(var k = -180; k <= 0; k += 2) {
line.push(k); // lat
line.push(x); //lon
polyLinesLon1.add({
positions : Cesium.Cartesian3.fromDegreesArray(line),
width : 1,
material : new Cesium.Material.fromType('Color', {
color: Cesium.Color.BLACK.withAlpha(0.10)
asynchronous : false
line = ;
line = ;
for(x = -90; x <= 90; x+=0.1){
for(var j = -0; j <= 180; j += 2) {
line.push(j); // lat
line.push(x); //lon
polyLinesLon2.add({
width : 1,
line = ;
for(var b = -180; b <= 0; b += 2) {
line.push(x); // lat
line.push(b); //lon
polyLinesLat1.add({
width : 1,
line = ;
line = ;
for(var n = 0; n <= 180; n += 2) {
line.push(n);
polyLinesLat2.add({
width : 1,
line = ;
// 1 unit of measure function
function createGrid(){
polyLines = new Cesium.PolylineCollection();
var line = ;
// Create a color material with fromType:
for(var x = -90; x < 90; x+=2){
for(var k = -180; k < 182; k += 2) {
line.push(x); //lon
polyLines.add({
width : 1,
line = ;
line = ;
for(var n = -180; n < 182; n += 2) {
line.push(n);
polyLines.add({
width : 1,
line = ;
If anyone has any suggestions for any of the two ways to create a static grid system that matches the longitude and latitude please let me know!
I saw another question about this same subject, but I was confused on how to proceed.
Thanks
