I’m creating a custom primitive, basically a cone/pyramid/frustum that will project a texture into the terrain.
It renders fine, but when I put a certain rotation matrix on the primitive, it suddenly gives a weird exception.
As you can see, it is somehow related to splitting the geometry down longitude lines.
Why this is done automatically be Cesium?
It is necessary? Anyway to disable or avoid the exception by somehow modifying the geometry?
DeveloperError: All attribute lists must have the same number of attributes.
Error
at new DeveloperError (http://localhost:8080/Build/Cesium/Cesium.js:1282:19)
at Function.Geometry.computeNumberOfVertices (http://localhost:8080/Build/Cesium/Cesium.js:16366:27)
at updateGeometryAfterSplit (http://localhost:8080/Build/Cesium/Cesium.js:26880:41)
at updateInstanceAfterSplit (http://localhost:8080/Build/Cesium/Cesium.js:26919:24)
at splitLongitudeLines (http://localhost:8080/Build/Cesium/Cesium.js:27234:9)
at Object.GeometryPipeline.splitLongitude (http://localhost:8080/Build/Cesium/Cesium.js:27484:17)
at geometryPipeline (http://localhost:8080/Build/Cesium/Cesium.js:76666:34)
at Object.PrimitivePipeline.combineGeometry (http://localhost:8080/Build/Cesium/Cesium.js:76889:26)
at Primitive.update (http://localhost:8080/Build/Cesium/Cesium.js:78303:48)
at VisionConePrimitive.update (http://localhost:8080/Apps/Inovaworks/VisionConePrimitive.js:659:26)
at PrimitiveCollection.update (http://localhost:8080/Build/Cesium/Cesium.js:119944:27)
at updatePrimitives (http://localhost:8080/Build/Cesium/Cesium.js:125271:27)
at render (http://localhost:8080/Build/Cesium/Cesium.js:125324:9)
at Scene.render (http://localhost:8080/Build/Cesium/Cesium.js:125365:13)
at CesiumWidget.render (http://localhost:8080/Build/Cesium/Cesium.js:134707:25)
at render (http://localhost:8080/Build/Cesium/Cesium.js:134182:32)
