Support for running on x86-64 Android(Magic Leap 2)?
I’m able to build the Cesium for Unity Sample Project to a Magic Leap 2, but Cesium will not load the map on the device, it throws the following error:
NotImplementedException: The native implementation is missing so Update cannot be invoked. This may be caused by a missing call to CreateImplementation in one of your constructors, or it may be that the entire native implementation shared library is missing or out of date.
Is support for x86-64 Android on the roadmap, or at the very least a temporary work around for this specific issue?
That error indicates that the native code is missing, because we don’t include built binaries for Android on x86-64, mostly because we don’t have any such devices ourselves. There shouldn’t be an major barriers to building on that platform, though, by following the developer instructions:
Hey @Kevin_Ring ,
Thank you for the quick response. I didn’t have much luck with the linked documentation, but I did see that you recently created a PR for supporting Android x86_64. I went ahead and pulled that code to attempt a build. The build does fail, though seems to be on the right track. I’ve attached the build log. Please let me know if I can provide anymore information. Thank you for the support!
Matt
build.zip (3.5 KB)
Looks like you’re missing the changes in the tinyxml2 submodule. Run git submodule update --init --recursive, then delete all your build directories and try again.
Or, you can just download the pre-built package from our CI system. Go here:
Download the Combined Package, extract the .tgz file from it, and install it using the Unity Package Manager.
Kevin
Running the submodule update command was all it needed, Cesium now builds and runs on the Magic Leap 2, thank you!
Matt
That’s great, thanks for letting us know!
