Hi all,
I currently work on integrating an orthographic camera mode into our application.
As I encountered some issues I wanted to create a Sandcastle that can explain my problem. But when I started to play around with the Sandcastle I quickly ran into another problem and I think before I can discuss my initial problem this one needs to be addressed as it is quite similar but not the same.
I just added the projectionPicker widget to the 3D Tiles Point Cloud sandcastle. When switching to orthographic mode something in the rendering gets broken (see the screenshot). I can reproduce this with Chrome, Firefox and Edge. Sometimes it seems to just be a black screen, sometimes a distorted portion of the globe is visible. Panning/Rotating doesn’t help but as soon as I zoom in or out the rendering is correct again.
My initial problem was that in our application a point cloud would sometimes disappear after switching to orthographic but it’s hard to reproduce this if I can’t even use the built-in widget to switch to an orthographic frustum ![]()
Sandcastle example (modified 3D Tiles Point Cloud example to include projection picker):
I think the projection picker should work out of the box with every sandcastle example, shouldn’t it?
Cesium 1.65 (Sandcastle), Windows 10, Chrome 79/Frefox 65/Edge 44
