hey,
Within CHANGE.md for Cesium 1.35 it means that instead of “throttleRequestByServer” you can now use “RequestScheduler. throttleRequest”. When I look at RequestScheduler, there is no method “throttleRequest”. Can someone please tell me what I’m doing wrong, or what I should use instead?
**for a custom terrain provider we use throttleRequestByServer. ******
regards
Jerry
Ah sorry, the CHANGES.md documentation is wrong. I’ll push a fix for that.
The throttling now goes through the load functions directly. So if you are requesting an ArrayBuffer resource, you would write:
Cesium.loadArrayBuffer(url, headers, new Cesium.Request({
throttleByServer: true
})).then(function(arrayBuffer) {
// If arrayBuffer is undefined, the request was throttled
This is essentially the method that other terrain providers use to throttle requests.
Opened the issue here: https://github.com/AnalyticalGraphicsInc/cesium/pull/5935.
Also let me know if this works for you.
