I have some geotiff imagery data that I’m uploading to cesium ion. Despite its extent being 0 - 360 degrees, once cesium has finished tiling only half of the data seems to appear.
Below is the gdalinfo report for the geotiff in question:
Driver: GTiff/GeoTIFF
Files: t_out.tiff
Size is 3072, 1536
Coordinate System is:
GEOGCRS["Coordinate System imported from GRIB file",
DATUM["unnamed",
ELLIPSOID["Sphere",6371229,0,
LENGTHUNIT["metre",1,
ID["EPSG",9001]]]],
PRIMEM["Greenwich",0,
ANGLEUNIT["degree",0.0174532925199433,
ID["EPSG",9122]]],
CS[ellipsoidal,2],
AXIS["latitude",north,
ORDER[1],
ID["EPSG",9122]]],
AXIS["longitude",east,
ORDER[2],
ID["EPSG",9122]]]]
Data axis to CRS axis mapping: 2,1
Origin = (-0.058593750081407,89.968897500977207)
Pixel Size = (0.117187500162813,-0.117147001954397)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -0.0585938, 89.9688975) ( 0d 3'30.94"W, 89d58' 8.03"N)
Lower Left ( -0.0585938, -89.9688975) ( 0d 3'30.94"W, 89d58' 8.03"S)
Upper Right ( 359.941, 89.969) (359d56'29.06"E, 89d58' 8.03"N)
Lower Right ( 359.941, -89.969) (359d56'29.06"E, 89d58' 8.03"S)
Center ( 179.9414065, 0.0000000) (179d56'29.06"E, 0d 0' 0.00"N)
Band 1 Block=3072x1 Type=Float64, ColorInterp=Gray
The data is a single band extracted from a GRIB2 dataset, hence the CRS.
What could be causing this? The file renders fine in QGIS. I suspect it has something to do with the unorthodox CRS it has, although warping the file to EPSG:4326 and uploading that does not appear to make a difference. Does cesium ion expect (0,0) to be centered?
Thanks
