Time dynamic data from js function
Hello Cesium community,
I am trying to make an application which would vizualize a trajectory of a low Earth spacecraft. This is easily achievable by loading a czml. However, I would like to provide cesium the position at any time myself. For example, I would like to write a javascript function taking time as input and providing a cartesian position for a perfectly circular orbit as output. Is there a way to pass this function to cesium so it can vizualize it, for example with a trail and attached model ?
To give a bit of context, the idea behind my app is to allow vizualization of trajectories stored on server side in a binary format. I have a c library to read/interpolate these files. I wrote a node js addon to call the library from a node js script. Now, I could write a js function on the client/browser side which would take time as input, call the server (I was thinking of socket.io) and receive the position which would then be passed to Cesium.
I am quite new to cesium/js. In fact I ‘dived’ into js only because of cesium… So my question may be naive or the answer obvious.
Hi Petr,
Sounds like a great project you are working on. Here are some resources for time dynamic data where you can control the position that can help you get started:
Moving vehicle with interpolated positions
Building a flight tracker with custom JSON latitude, longitude, and height data
Please follow up with additional questions as necessary.
Hi Dzung,
the vehicle example is really nice ! The Cesium.CallbackProperty is what I was looking for. Its a user defined function of time used in the example to set the text and the wheel orientation. I tried if its possible to set an entity’s position with the CallbackProperty as well and it works:
function updatePosition(time, result) {
          var tt = Cesium.JulianDate.secondsDifference(time, start);
          var currentPosition = new Cesium.Cartesian3();
          currentPosition.x = startPosition.x + tt * (endPosition.x - startPosition.x);
          currentPosition.y = startPosition.y + tt * (endPosition.y - startPosition.y);
          currentPosition.z = startPosition.z + tt * (endPosition.z - startPosition.z);
          return currentPosition;
var vehicleEntity = viewer.entities.add({
    position: new Cesium.CallbackProperty(updatePosition, false),
The car changes linearly its position as specified in the updatePosition function.
Many thanks for your help.
Great! Glad you found it helpful. Welcome to the Cesium community!
