To find intersection point of geometric entites
hi all,
Im making a application in which im using cesium geometric entities. like circle, polygon, polyline, . All in objects in 3D.
I need to find intersection points of line with circle or polygon. Line is drawn vertically up from ground (say 10 meters or 500 meters) and there is a rectangle/ circle or polygon drawn above ground (say 200 meters). how do i find the point of intersection on line.
Once I am able to find the point of intersection then I would say this line is permitted. if the line touchs or cross the rectangle then i’ll say this height is not permissible, and ask the line to be cut
Iam using cesium 1.63.
(sorry to ask lot of question… should i use any thing other than geometry elements ? )
@meseenu1979
were you able to solve this problem ?
thanks !!
may be this link can help
https://cesium.com/learn/cesiumjs/ref-doc/IntersectionTests.html?classFilter=test
