Track czml polyline
Hi there,
I have a CZML file that contains 1 polyline entity following this structure
        version: "1.0"
        polyline:
          positions:
            cartographicDegrees: [lat1,lon1,alt1,lat2....]
What I have in my render.js.
 const source = new Cesium.CzmlDataSource()
 const promise = dataSource.load(czmlUrl) //
 viewer.dataSources.add(promise)
 promise.then(v => v.trackedEntity = v.entities.getById("line_1")
The line is rendered, but it is not focused. One solution that I came up with is to extract 1 set of lat, lon and alt then create an entity for “trackedEntity” or use the three points to “lookAt”. But I don’t really want to have a czml reader in the render.js. Is there any other way to solve this issue?
Thanks
I think you are trying to set trackedEntity to the wrong object.
Could you try the code below?
promise.then(v => viewer.trackedEntity = v.entities.getById("line_1"))
