Our application is having trouble connecting to Cesium 3D tile sets using the URL https://assets.cesium.com/{asset id}/tileset.json.
The JS console shows a Failed to load resource: A server with the specified hostname could not be found error when attempting to connect. We’re using Deck.gl as a viewer.
There is a thread about this on the Deck.gl GitHub issue tracker: [Bug]Tile3DLayer example is broken · Issue #7550 · visgl/deck.gl · GitHub
Also nslookup assets.cesium.com doesn’t return an answer. Has the URL structure changed?
I’m sorry the recent infrastructure change has caused an issue.
The assets.cesium.com url was never designed to be hardcoded into applications and is an implementation detail of the GET /v1/assets/{assetId}/endpoint route. Clients should always use the response url property to access asset files.
There are lots of use cases for why this is done this way, for example we can send clients in different geographic parts of the world to different servers, or ion may eventually support geofencing to ensure data remains in a specific geographic region and send clients to those URLs accordingly.
I apologize if the documentation did not explicitly make it clear that this URL should not be cached or assumed. We’ll look into updating the documentation to make this clear.
Is it possible to patch the deck.gl code to remove this assumption?
Matt
Hi Matt,
Thanks for the response. It should be possible to update our application code to use the url property of the GET response. We’ll look into that.
In the very short term, switching the base URL to assets.ion.cesium.com fixes the issue.
The docs could make the need to avoid hardcoding the URL a bit more clear, so if they can be updated that’s great. Also, the status.cesium.com still references assets.cesium.com which is a bit misleading since the URL doesn’t resolve.
An email advising account holders (especially paying clients) of the infrastructure change and potential side effects would also have been helpful - apologies if one was sent and I missed it.
Mark
Hi, I did not get access anymore to the CesiumRasterOverlay asset. It worked very well until yesterday and now, I have no Polygon panel visible (to select Cartographic Polygon). In place of it here is a button “Troubleshoot token” and when I click on, it seems that the asset no more exists in my Cesium account or there is no authorization to access to it. When i click on “Authorize access”, Unreal crash …
Thank you for your help
I precise that I use UE 5.1 and Cesium 2.1
@Mathieuvannereux This sounds like it might be unrelated to the original topic of this thread. You might consider opening a new thread in the “Cesium For Unreal” section at Cesium for Unreal - Cesium Community , including a detailed description of your setup, and details about the exact workflows and error messages.
