Cesium Tilesets dont load on pixelstream service
Hello everyone,
Since yesterday we are having issues with loading our tilesets via ion source.
We are hosting our unreal apps on a pixelstream service. Since yesterday all of the apps dont show the tilesets anymore. We cant reproduce this localy or in unreal itself. What we have noticed is that it does work when loading the tilesets via an url (tested with google tilesets) instead of the ion id.
Since we use a lot of very big tilesets we cant include the tilesets directly in the build to load them via url.
We tryed reaching out to the pixelstream service (Arcware) and they were aware of the problem, since other customers were facing it aswell. But they told us that they didnt change anything.
We assume it could be because certain ip adresses or requests get blocked. Were there any chances from your end?
If this is to little information, please let me know and i can follow up with a detailed description of our setup. Also if there are any informations regaring the pixelstream service that are needed to resolve this.
Thank you in advance,
Hegais
Hi @HEGIAS, this is an issue we’ve been hearing from other customers as well today. Our AWS certificates were renewed this week, and we suspect this is the issue. Can you try the following to see if it helps?
  • Clearing the DNS cache on the machine.
  • Delete the cesium-request-cache.sqlite file, which should be located in the Engine directory of the packaged app.
  • Restarting the machine that Cesium for Unreal is running on after performing the previous two steps.
Hi azrogers,
I also created a post about this issue in a packaged game. I tried the steps above and that did not fix the issue for me in a packaged game.
Sorry to tag in here, trying to find solutions.
Thank you very much!
Hello! I’m facing this issue as well.
  • Clearing DNS isn’t possible(?) because I use Arcware to rent VM’s for Pixel Streaming.
  • I’ve deleted cesium-request-cache.sqlite, reuploaded the package, and tiles still don’t stream.
  • Restarting the machine shouldn’t(?) matter, as the VM’s startup on request.
I’m not sure how installing the Starfield Services Root Certificate Authority from AWS will work, since I rent out VM’s from Arcware, as recommended HERE
My project is packaged to Windows. This issue arrived within the last month. All of my previously uploaded and working projects are broken, failing to load your gorgeous tile sets :frowning:
I can provide a link to the Arcware stream and/or .zip package directly to a Cesium Team member, if requested.
Hope to get this fixed soon… Thank you!
We are also in contact with arcware to find a solution. I will update here aswell as soon as we have found something that solves the problem or some meaningful next steps are defined.
Hegais
Sounds good. The Arcware team also notified users on their discord. Thanks for your help
@CoulterHeiberger would you mind sharing Arcware’s message from their Discord? I’m curious what they’re saying about it, and am not on their Discord to check myself.
Yes I can. Here it is:
Manos | Arcware Today at 5:19 AM
Dear Arcware Community, We are aware of the recent issue affecting the loading of 3D Tiles in packaged Unreal applications that utilize the Cesium plugin. Cesium has identified that this issue may be linked to the recent renewal of their AWS certificates, which has impacted the ability of packaged applications to load 3D Tiles correctly. We apologize for any inconvenience this may cause and want to assure you that we are actively collaborating with the Cesium team to resolve this matter as quickly as possible. We appreciate your patience and will keep you updated on progress. Thank you for your understanding as we work to restore full functionality of the plugin. Cesium community forum link : KNOWN ISSUE: Tilesets not loading in packaged Unreal apps Warm regards @everyone, The Arcware Cloud Team
Cesium Community
The last part referred to this forum.
Seems like the problem is solved. Arcware is working good now.
Here’s their latest Discord message:
"Manos | Arcware — Today at 8:37 AM
We’re pleased to announce that the issue affecting 3D Tiles loading in packaged Unreal applications using the Cesium plugin has been resolved! Our team, in close collaboration with Cesium, has deployed the necessary fix, and functionality should now be restored across all applications.
Please let us know if you continue to experience any problems. If any issues persist, feel free to direct message me, and I’ll be happy to assist.
Thank you for your patience and support as we worked through this!
Warm regards to @everyone,
The Arcware Cloud Team"
Great news, thanks for letting us know @CoulterHeiberger!
